IGNITER
- Hawk111
30 Jun 2010 14:35 #379268
by Hawk111
IGNITER was created by Hawk111
I have a kz750 igniter on my bike right now, however, my bike is a kz550. Is this a proper substitute or should I not do this?
- anarki650
- Thank you received: 5
30 Jun 2010 14:48 #379271
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic IGNITER
Pretty well all the Ma Kaw igniters are interchangeable. At one time I had an ignition plate off a kz550, an igniter off a kz1000, and coils off a kz750 electronic ignition on one of my kz650s.
The ignition plate on the kz1000 is slightly different than the smaller bikes, but can be modified to work on the small ones with a dremel and a little time.
09 Kawasaki ER6n
Omaha NE
- JR
- Thank you received: 447
30 Jun 2010 19:16 #379340
by JR
Replied by JR on topic IGNITER
You're good.
I remembered loudhvx posted on building s replacement igniter snd the 550 one works on the 750 snd vice versaI double checked on kawasaki.com parts diagrams and yes the same igniter from the 750 is used on the 550, A1 A2 A3 A4 C1 C2 C3 C4 D1 and F1 models.
Try Kawasaki.com parts diagrams and drill down to the part. \Click on the part # and then the little yellow ? mark to see where used
- loudhvx
- Thank you received: 1616
30 Jun 2010 19:39 #379350
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic IGNITER
I think the only ones that may not be interchangeable are the electronic-advance ones. If it has a mechanical advancer, they should all be interchangeable. I always like the way Kaw likes to use a lot of interchangeable parts between models.
1981 KZ550 D1 gpz.
Other links.
