Installing new DYna Green Coils
- eddyshore
29 Jun 2010 11:52 #378988
by eddyshore
1979 KZ650 Cafe Racer Project
Installing new DYna Green Coils was created by eddyshore
Anyone got a diagram on how to install new dyna green coils on a KZ650 Thanks in Advance , James
- hocbj23
- Visitor
29 Jun 2010 12:09 #378994
by hocbj23
Replied by hocbj23 on topic Installing new DYna Green Coils
Dyna has a good tech section that should be able to help u.bj
- Thank you received: 2098
29 Jun 2010 12:35 #378998
by Patton
29 Jun 2010 12:36 - 29 Jun 2010 12:40 #378999
by Patton
Replied by Patton on topic Installing new DYna Green Coils
[Patton screwed up.]
:pinch:
Please see following post.
Last edit: 29 Jun 2010 12:40 by Patton.
29 Jun 2010 12:37 #379001
by Patton
29 Jun 2010 12:46 #379004
by Patton
29 Jun 2010 12:48 - 29 Jun 2010 15:17 #379005
by Patton
Last edit: 29 Jun 2010 15:17 by Patton.
29 Jun 2010 12:48 #379006
by Patton
- MFolks
- Thank you received: 540
29 Jun 2010 13:29 #379011
by MFolks
Replied by MFolks on topic Installing new DYna Green Coils
The only problem I had when installing the 3 ohm Dyna Green ignition coils on my bike was the primary wire hook ups.
Kawasaki used 1/4" wide push on terminals when the bikes came from the factory, the Dyna's use 10-32 X 5/16" long screws for the primary wires.You'll have to cut off,strip insulation and crimp on new "ring" terminals for the new coils.
I'd advise using a lock washer and flat washer of some type to secure the wire terminals. Be careful in not "bottoming" out the screws before they get tight or you might break off a screw in the coil(s).
- eddyshore
30 Jun 2010 08:01 #379199
by eddyshore
Replied by eddyshore on topic Installing new DYna Green Coils
How do the spark plug wires hook to the coils ? Am
I right in assuming you crimp the end of the wire enough to slide it into the coil? And does it matter which wire goes to which ? And does it matter which wire goes to which screw in terminal ? Cause I hook up one coil and tested it for spark and still got nothing .....
- cobura
- forever 2 wheels
- Thank you received: 3
30 Jun 2010 08:14 #379200
by cobura
1979 KZ650B3
Replied by cobura on topic Installing new DYna Green Coils
You should get spark regardless of which coil you hooked the plug up to. But YES, it is very important which wires go to which coil. One coil will provide spark to cylinders 2 & 3 while the other coil will provide spark to cylinders 1&4.
1979 KZ650B3
- MFolks
30 Jun 2010 08:53 #379207
by MFolks
Dyna supplies the standard brass termination to fit the sparkplug wire to the ignition coils. Make sure enough insulation is stripped back to allow the inner conductor to fold under the termination before crimping it.
It might require a special crimper as the crimps should be round in shape to fit the coils ports.
