coil trouble 1977 KZ650B1
- lgj069
24 Jun 2010 23:02
Hey all. While checking the spark plugs today I pulled one of the wires off of the plug and the cap came off in my hand. Can this be repaired, or should I get a new one?
PEACE Larry
PEACE Larry
- bountyhunter
Re: coil trouble 1977 KZ650B1
25 Jun 2010 00:14
If you mean the cap that goes on the plug, it pulls off easily. They screw into the end of the thick rubber wire and after time, they will pull out because the wire gets worn away. Sometimes you can nip 1/4" off the end of the plug wire and screw the cap back in as long as you have enough free wire. You can also buy new caps from Z1 if yours are worn out.
- lgj069
