throttle cable
- lgj069
throttle cable
19 Jun 2010 09:31 - 19 Jun 2010 09:35
OK fellas, got my bike back together, it runs OK. My problem is some where in the throttle. Never worked with a accelerator decelerator cable before, and I can not get my brain around how they function. I have read both of the manuals but I still do not get it. I guess what I want too know is, are there any tips/tricks you folks can share with me? Thanx for your time and efforts ... PEACE Larry I almost forgot it is a 1977 KZ650B1
Last edit: 19 Jun 2010 09:35 by lgj069.
Re: throttle cable
19 Jun 2010 10:36
One cable pulls the throttles open, the other is attached to the opposite side of the throttle mechanism and pulls the throttles closed.
Adjust per fsm and ride it like you stole it.
- RonKZ650
Re: throttle cable
19 Jun 2010 10:49
Either that or ditch the push cable in the trash. With lower than stock bars on a KZ1000 I literally tried for 3 yrs to make the push/pull work together but it wouldn't so I had basically a cruise control because the throttle would stick constantly. I finally cut the inner cable of the push disabling it and left the outer cable on so it looked stock and not hacked and used the pull only which needless to say works just fine. Push/pull works ok on all my stock motorcycles, but not necessary.
- Kawickrice
Re: throttle cable
19 Jun 2010 11:02
There are adjustments at the handlebars and down by the carbs on the cables. Try the handlebar adjustments first
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Re: throttle cable
19 Jun 2010 11:17 - 19 Jun 2010 12:11
For eons, only a single throttle cable was fitted to pull the carb slides open. And a spring was relied upon to pull the slides closed. Many of the return springs were located inside the carbs.
If in the rare event that the return spring failed, or the throttle cable hung up for whatever reason, the engine would not return to idle rpm. And, yikes, runaway bike. :woohoo:
Okay, that's what kill switches are for.
The second throttle cable was added, imo, to serve as a fail-safe means whereby the throttle slides could be manually pulled closed without relying on a spring to pull them closed.
Some riders tire of the ultra stiff throttle return spring, and simply remove the spring. Which allows throttle control both up and down with very little effort. But must remember to manually close the throttle, which quickly becomes a habit.
One risk is a dropped bike with runaway throttle, that won't close the throttle automatically absent human control, which may result in engine damage and other bad things.
I opt for the simple friction type throttle control, but realize and accept the risk involved.
Have also experimented with replacing the super-stiff oem return spring with a softer hardware store spring. Which actually works pretty well.
Last edit: 19 Jun 2010 12:11 by Patton.
- lgj069
Re: throttle cable
19 Jun 2010 11:44
Thank you one and all. I think that push cable is outta there!!
