82 KZ750R1 Wiring Help
  • nicksorg
  • nicksorg's Avatar Topic Author
18 Jun 2010 09:33
#376587
When I bought this 82 GPZ750 a couple of weeks ago, I got all of the electrical hooked up and was able to turn over the starter. The harness was pretty hacked up and I had a chance to buy a same year/model harness. I swapped in the new harness and have a question:
Facing front, on the right side seat area, there are 4 bullet connectors that I don't know what to do with. According to the wiring diagram, two are extra and were cut on the old harness. There is a pink one that I believe is for the battery monitor that I don't have on my battery. Lastly there is a black/yellow connector that the PO spliced into the engine ground wire. Where should this normally connect?
Thanks
Nick
1982 Kawasaki KZ1000-K2
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 82 KZ750R1 Wiring Help
18 Jun 2010 10:36
#376596
If I get a chance, I'll look when I get home this evening.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • nicksorg
20 Jun 2010 15:30
#377090
I went through my parts box and found the ground cable that goes from the engine to the battery. This cable had the bullet connector I was looking for.
Thanks
Nick
  • MFolks
  • MFolks's Avatar
20 Jun 2010 19:17
#377134
The BLACK with YELLOW stripe is the common ground in most Kawasaki's.
