Pulsing halogen Headlight Shorten Life?
- bountyhunter
Re: Pulsing halogen Headlight Shorten Life?
15 Jun 2010 14:03 - 15 Jun 2010 14:07
There are a lot of them available and probably for less $ than it would cost to build it, but I am an out of work design engineer with too much time to kill so I am trying to find a simpler way to do it. Also, doing it in a way that violates the DOT specs is a plus for me.:laugh:
They spec that the pulser must be in the positive lead, not ground lead.
Last edit: 15 Jun 2010 14:07 by bountyhunter.
- otakar
15 Jun 2010 14:39
A little off the subject but still along the same lines; On a CF13JL-2 Flasher unit, that is commonly available and good to 20A, Which resistor would have to be changed to vary the flash rate. Since this is good to about 240W it could be modifiable, it it can be made to flash at between 3.3-4.7Hz. I took one apart and would at least like to try.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
15 Jun 2010 14:40
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
15 Jun 2010 14:43 - 15 Jun 2010 14:45
I found this link that shows how to do it on a little different stile flasher and am attempting to do it to the CF13. He removed the 100K R1 and replaced it with a variable 500K.
www.instructables.com/id/Automotive-elec...n./step6/Schematics/
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Jun 2010 14:45 by otakar.
- loudhvx
15 Jun 2010 20:20 - 15 Jun 2010 23:02
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 15 Jun 2010 23:02 by loudhvx.
- loudhvx
15 Jun 2010 20:22 - 15 Jun 2010 20:37
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 15 Jun 2010 20:37 by loudhvx.
