Engine noise? Nope!!!
  • KZ1100 Bully
  • KZ1100 Bully's Avatar Topic Author
10 Jun 2010 07:57
#374857
Well I have a rattling noise in the front of the bike. Only at 2200 to 2300 rpm. Thought it might be the cam chain but I just replaced that maybe it is the lifters, could be the exhaust. Thought it could be the gauges or the headlight.
It turns out to be the wires in the back of the headlight. And theirs is a lot of them.
Any idea how to stop those wires from rattling around? I tried moving the wires around but it only changed the rpm setting it would rattle. Thought maybe some spray foam or something.
1983 Kawasaki KZ1100 Spectre D2
  • Motor Head
  • Motor Head's Avatar
Re: Engine noise? Nope!!!
10 Jun 2010 08:16
#374861
Foam tape or bubble wrap, that way you can still access the connectors when needed.
10 Jun 2010 09:48
#374874
I don't know, but it may get pretty hot inside the headlight shell. Maybe a wad of fiberglass insulation in the back of the shell would serve as padding? Ed
  • MFolks
  • MFolks's Avatar
10 Jun 2010 10:17
#374883
I'd try a few ty-wraps to bundle the wires together. It will change the vibration frequency when tied this way.
  • KZ1100 Bully
13 Jun 2010 13:57
#375483
Right on guys thanks for the tips. I wrapped the wires with some new electrical tape. I placed the bundle of wires in a old sock and I put that in a heavy duty rubber glove. I cut the fingers off the glove and used a few ties to hold it all together.
No more noisy headlight wires.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
13 Jun 2010 14:00
#375485
if that doesnt work, take out your baffle. you wont hear the rattle anymore.:P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
