Changing the ignition switch (key)
  • gte105u
  • gte105u's Avatar Topic Author
09 Jun 2010 13:22
#374660
I have a new ignition switch on the way for my '81 KZ550. I was thumbing through the manual and did not see where it talks about how to change this out. Anyone have any info to pass along? How do you get down to it, anything that might surprise me, is it overall pretty simple?
1981 KZ550 A2
  • MFolks
  • MFolks's Avatar
Re: Changing the ignition switch (key)
09 Jun 2010 14:39
#374673
On my 82 GPz1100, I have to lower the headlight housing(remove the headlight to prevent breaking the glass)to gain access to the two socket head cap screws(Allen Screws) holding the ignition switch to it's mounting place.
The wiring will simply unplug with the new switches wiring plugging in it's place.
For safety's sake, disconnect the BLACK(-) Negative battery terminal to prevent fire,smoke,explosions, and general panic before doing the repair/replacement.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
10 Jun 2010 04:29 - 21 Feb 2013 01:52
#374811
Last edit: 21 Feb 2013 01:52 by H1Vindicator.
  • gte105u
19 Jun 2010 16:38
#376859
Thanks for the tips guys. Got the parts in last night and changed today. Works great
1981 KZ550 A2
  • MFolks
  • MFolks's Avatar
19 Jun 2010 19:24
#376906
These old ignition switches get a lot of use,and vibration is not kind to them either.
