81 KZ1000 CSR wont start
  • wannaby
  • wannaby's Avatar
Re: 81 KZ1000 CSR wont start
07 Jun 2010 16:15
#374202
Thx ill try that and let ya know...
  • wannaby
  • wannaby's Avatar
07 Jun 2010 22:18
#374312
lifted the fusebox and everything looks nice and clean....
  • MFolks
  • MFolks's Avatar
07 Jun 2010 22:24
#374314
Get a multimeter set on ohms and continuity check the fuses. The glass tubed fuses can fail but still look good.
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net www.delcity.net/cartviewitem?item=73805&search=y
  • wannaby
  • wannaby's Avatar
07 Jun 2010 23:02
#374319
Checked continuity on all fuses and everything is good.
