73 z1 Trying to get running after 20 years HELP
  • BadAssRX7
  • BadAssRX7's Avatar Topic Author
06 Jun 2010 15:14
#373946
ok tring to get a 73 z1 back up and running after sitting up for 20 years. The owner is having some issues rembering stuff and that with some elct. issues is killin me. the bike showed no life with a good battery and fuse but after sitting on the seat the lights (cluster) lite up with the key 1 click to the right from off. But they all turn off when 2 clicks to the right.
#1 is run 1 click or 2 clicks to the right?
#2 any common issues with wiring? im also getting no starter , i chcked the kill switch and the starter switch both are good.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 73 z1 Trying to get running after 20 years HELP
06 Jun 2010 16:21
#373964
start checking for loose connections/bad grounds,is the battery new?
  • MFolks
  • MFolks's Avatar
06 Jun 2010 16:27
#373965
Get some metal polish(I like Basso)and some cotton swabs to clean the fuse clips. Replace if possible the fuses as they have no doubt died.
Look here:
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net www.delcity.net/cartviewitem?item=73805&search=y
  • BadAssRX7
06 Jun 2010 17:03
#373972
yep new battery and fully charged(1st thing i checked). this z1 only has 1 fuse its a glass type and checked out ok with a dvo meter but ill see if i have the right size and swap it.
so i didnt get a reply about the key postion is it (l-R)
off-run-park
or
off-park-run
  • larrycavan
  • larrycavan's Avatar
06 Jun 2010 17:15
#373973
off-run-park
or
off-park-run
left to right - off - run - park
  • BadAssRX7
06 Jun 2010 18:11
#373985
thanks that helps alot so now i can go wire by wire and start checkin the harness
  • Old Man Rock
  • Old Man Rock's Avatar
07 Jun 2010 05:03
#374050
Here, maybe this will help....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Kawickrice
  • Kawickrice's Avatar
07 Jun 2010 08:23
#374072
Have you tried to bump the solenoid with a screwdriver to see if you get anything at all as far as the starter turning over?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • wannaby
  • wannaby's Avatar
07 Jun 2010 09:52
#374084
wouldnt that mayby break something on the starter if it was frozen would it be an idea to pull the starter and check it out...is it hard to pull the starter..does it come right out or do you have to pull the starter gear before pulling the starter....
  • Kawickrice
07 Jun 2010 09:55
#374086
Will the motor turn over with the kicker? If yes then it will not hurt it but if the motor is seized it might trash the starter
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • BadAssRX7
13 Jun 2010 02:20
#375396
old man rock thank you and i hate you... I scaned a copy of the harness and did a bad coloring job on mine compared to yours. Thanks!
  • BadAssRX7
13 Jun 2010 02:38
#375398
ok the motor will spin just fine... with the kick starter. I did a few things before i gave the ok to the owner to start droping money into this bike. He is the original owner and had it parked in his climate controled garage. I pulled the plugs and mmoed the cyl. and kicked it over slowly a few times with no issues. poped the tank open and found MAJOR issue #1 rusted and goo. Carbs were full of goo also. we also looked at wheels, brakes, bearings, cables. ordered lots of stuff and sent the carbs off to redline i think. well then we striped it to the frame. preped and painted the frame, got the custom mags all blinged out again and dressed with new discs pads and rubber. so skip a bit to last week. its all hooked up and had a good batery but was getting no power to the cluster. i checked the switchs out all were good. The wiring harness was in ruff shape and he found a ebay company z1... that listes aftermarket oem quality new harnesses for it and a good price. so we get that and im removing the oem and installing the new. and i have found 1 issue with the new harness. its got both brown and brown /white stripe wires. the harness doesnt show a br/w wire. untill 75-76 so im scratchin my head wondering what this goes to.all in all the harness is nice. all new dash lights (194 bulbs) the only thing i have found is 3 smaller harness should come in this harness kit.... the headlight doesent, and both battery cables dont.
anybody else use this companys harness and have the br/w wire issue? im hopin to spin it today really id like to b 4 noon... from a test tank after she fires up ill be alot happyier and then its just the small stuff.... idle ajustments, bradied hoses and cables install and the bodywork.
