Which Dyna coils are best!!
- lrburke
05 Jun 2010 05:06
Hey Guys, I need to know which Dyna coils are correct for a 1981 KZ750H2. The bike has factory electronic ignition and the OEM coils are reading about 2.4 ohms on the primary side but the Factory Kawasaki manual says a range of 1.8 to 2.8. I was thinking the Gray 2.2 ohm coils. Is this correct? Thanks again as usual!!!
Re: Which Dyna coils are best!!
05 Jun 2010 05:36 - 05 Jun 2010 05:37
lrburke wrote:
The gray 2.2 ohm coils should be okay.
With primary coil ohm check being within specs, am wondering about secondary loop, and need for new coils.
Is this a situation where oem coils have plug wires permanently affixed and the old wires have deteriorated, such as hardened, cracked and leaking?
Sometimes, an option might be plug wire splicers with new wires on the existing coils where coils remain in good condition.
Last edit: 05 Jun 2010 05:37 by Patton.
- lrburke
05 Jun 2010 06:57
Thanks for the response! I am actually working on this bike for a friend and he said to go ahead and replace the 30 year old coils. Both of the OEM coils have this black goo seeping out of them around where the phillips head mounting bolts are. It really looks like they have been getting extremely hot and the charging system is right where it should be! I have already replaced the plug wires with Dyna copper core but now he wants to replace the coils. Larry
