Advancer Springs...
  • TeK9iNe
  • TeK9iNe's Avatar Topic Author
  • What did you do!?!
Advancer Springs...
04 Jun 2010 15:14
#373456
Couldn't seem to find anything with the search feature...
I've noticed that since my last tuneup, that my timing marks (especially at idle), are bouncing around more and more. After a quick diagnosis, I've found my advancer springs are getting pretty weak/sloppy.
Am I going to find a terribly large change in the accelleration curve if I nip off the half coil and bend a new one up to strengthen the spring?
I can just replace them, but I'm curious if there is any benefit to shortening them, so full advance happens a little sooner... or later rather?
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Advancer Springs...
04 Jun 2010 17:25
#373482
Hey Tek... contact Jeff @ Z1 for this was brought up...oh crap a year or so ago and if I recall correctly, he was able to get them or had info on them regarding sizing and such....
Been awhile so maybe I'm all screwed up on it....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • bountyhunter
  • bountyhunter's Avatar
04 Jun 2010 19:54 - 04 Jun 2010 19:58
#373541
Cheers.
B)
I just went through this and ended up making new springs from some I got at Orchard Supply. Don't match perfectly (advances up a little sooner than stock) but the idle setting is rock solid now and it runs way better. Can't believe Kawi doesn't sell those forking springs.
The factory springs in mine were hardened and you would not be able to cut a coil and shorten it. I bought some springs and they were also very hard to work but eventually did it.
Last edit: 04 Jun 2010 19:58 by bountyhunter.
  • TeK9iNe
04 Jun 2010 20:26
#373545
All good info...
Thanks.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • loudhvx
  • loudhvx's Avatar
05 Jun 2010 02:17
#373584
That will be way too much pre-load on the spring if you cut that much off. Try this first: take off one spring and just close the end loops up a tiny bit. That usually tightens it up enough for me to get closer to the original advance curve. If I do both springs I usually end up tighter than the original advance curve. If yours are very loose you may need to do both.
