dyna s kz650.
- 4rugrat1
dyna s kz650.
04 Jun 2010 13:21
i need to know how to time my bike correctly, with a timing light. should i just follow the procedure in the book and time it the same as the points?
- anarki650
Re: dyna s kz650.
04 Jun 2010 14:35
I'd check with Dyna for installation and timing instructions if you don't have the instructions...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- RonKZ650
Re: dyna s kz650.
04 Jun 2010 15:24
It's real easy with a timing light. Hook up your timing light pickup to either plug #1 or 4 and start the engine. The timing light should show the bike timed at the "F" mark for 1-4, add throttle and watch the timing marks advance and the timing should be between the II marks. If not move your pickup for 1-4 on the plate until it's timed correctly. Move your timing light pickup to either cylinder 2 or 3 and do the same thing.
Re: dyna s kz650.
04 Jun 2010 18:20
4rugrat1 wrote:
Yes.i need to know how to time my bike correctly, with a timing light. should i just follow the procedure in the book and time it the same as the points?
- OnkelB
Re: dyna s kz650.
05 Jun 2010 14:07 - 05 Jun 2010 14:08
Installation and timing procedures in pdf format are right here:
www.dynaonline.com/skins/downloads/instruct/DS2-1_2-2.pdf
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 05 Jun 2010 14:08 by OnkelB.
