Green stuff inside my starter?
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
03 Jun 2010 19:05
#373238
Well, i posted a thread on here about a burned up starter..
I jumped the leads with a screw driver on the solenoid and nothing clicked or turned. My engine in my bike isn't locked, the wheel spins when the bike is pushed and in gear and the motor turns. I unbolted the solenoid and disconnected it from the harness. Its in a box in my kitchen. I then removed my clutch cover for my pushrod and removed the starter cover. I Took some booster cables and hooked up positive to the wire coming off the starter and grounded the other on the engine block. The starter turned a few times and then it stopped... it wouldn't turn anymore after that. I removed it the starter and hooked up the booster cables to it when it was sitting on the hood of our car. It spun freely but not smoothly and the surfaces where the motor bolts into the engine were dirty as hell so i wire brushed them off so they are clean now. I took the starter apart to look for any damage on the inside and this is what i found... I didn't pry on anything, the starter came right apart after unscrewing it. I don't know what the warped metal is...
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
Re: Green stuff inside my starter?
03 Jun 2010 19:07
#373240
Warped metal?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
03 Jun 2010 19:09
#373241
sorry, wont let me post my pictures, wrong size... The edge of the cylinder inside the starter is warped all to hell and there is green corrosion on the spindle that wound with copper... I think i need i new starter. The motor spins but makes a weird whining noise and it vibrates like crazy...
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • PLUMMEN
  • PLUMMEN's Avatar
03 Jun 2010 19:09
#373242
need a picture B)
  • Kitten Tooth
03 Jun 2010 19:15
#373244
Green stuff?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
03 Jun 2010 19:15
#373245
Sorry, i tried to post another pic, won't let me...
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • PLUMMEN
  • PLUMMEN's Avatar
03 Jun 2010 19:15
#373246
corrosion fromwater trapped in there,sounds like bad bearings B)
  • taildragger1197
  • taildragger1197's Avatar
03 Jun 2010 19:18
#373247
Green Stuff $$$$$$$$$$$$$$$
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
03 Jun 2010 19:25
#373251
yeah need a pic man!!! you can resize your pics in regular old microsoft paint..just go to stretch and skew and lower the numbers.
im an auto tech, and ive seen this before. you need a new starter!
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • bountyhunter
  • bountyhunter's Avatar
03 Jun 2010 21:50
#373282
The starter armature is loaded with bare copper which corrodes to a green color.
  • MFolks
  • MFolks's Avatar
03 Jun 2010 22:17
#373287
Try here if you think it can be rebuilt:
A. www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
B. www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm
Also ask around at the local electric motor rebuilding places that work on car starters.
  • Kitten Tooth
03 Jun 2010 22:23
#373288
I thought it was water... Im just going to buy a new one. The shell of the starter is all warped from heat. Its jacked i think. The inside is more of a wavy oval than anything like a circle... And i couldn't remember what the option was to resize my pics. Skew was somewhere in my brain but it wasn't anywhere in there where i was looking:D
Thanks guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
