blinkers
  • b.tracy79kz
  • b.tracy79kz's Avatar Topic Author
blinkers
03 Jun 2010 17:26
#373179
had after market turn signal on when i purchased bike,i wanted stock ,went to switch over and right side works and left side stays on but dont blink.any help thankful.
  • Motor Head
  • Motor Head's Avatar
Re: blinkers
03 Jun 2010 17:42
#373191
Check that the ground is good, sounds like it may be the problem. You did check to make sure that the correct bulbs are in the sockets?
  • MFolks
  • MFolks's Avatar
Re: blinkers
03 Jun 2010 18:52
#373230
For Kawasaki's with front running lights built into the turn signals, #1157 bulbs are needed.
The rear turn signals will take #1156 bulbs, the # 1157 is also used in the rear running/brake light(s).
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
Re: blinkers
03 Jun 2010 19:05
#373237
Absolutly!
do you have the running light circut mixed up with the blinker circut.
you can test this by turning on the left blinker and probing wires with test light and looking for the test light to blink....
;) expirence
-Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
