Key will not turn
  • gte105u
  • gte105u's Avatar Topic Author
Key will not turn
03 Jun 2010 15:56
#373147
I rode to work today, to and from lunch no problem. Trying to leave work and the key will not turn. It turned once but nothing happened. I turned it back to off, then it will not turn to on at all. The key still opens the tank fine. Help please!
1981 KZ550 A2
  • muddy1
  • muddy1's Avatar
  • 1980 Kz1000 LTD B4
Re: Key will not turn
03 Jun 2010 16:00
#373148
is the key bent? attempt to make it flat..
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • loudhvx
  • loudhvx's Avatar
03 Jun 2010 16:03
#373149
550 tanks are not actually keyed. So if the key is messed up, the tank won't be a good test. However, if you have to get a new lock, you won't have to worry about the tank, just the seat-lock.
To prove it, try a long skinny house key on the tank. It should open.
  • gte105u
03 Jun 2010 16:04
#373150
Key's flat. It worked fine and suddenly will not. Anyone ever heard of that. Sabatoge?
1981 KZ550 A2
  • bountyhunter
  • bountyhunter's Avatar
03 Jun 2010 17:12
#373168
Try some silicone spray into the lock mechanism.
  • MFolks
  • MFolks's Avatar
03 Jun 2010 18:56
#373233
Original ignition switch? Possible tumbler/spring failure. Only way I know to repair is to replace the switch.
  • RonKZ650
  • RonKZ650's Avatar
03 Jun 2010 19:23
#373248
Same thing happened to me last year and it was the key. Hard to understand how a key works fine one minute and not the next, but that's what happened in my case.
  • otakar
  • otakar's Avatar
03 Jun 2010 19:32
#373253
I have the same problem on my GPz1100 when the lock sits in the rain and is allowed to corrode on the inside. I just use a good light lube like LPS and spray it into the lock and it always works again.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • gte105u
03 Jun 2010 20:53
#373272
I am pretty sure it is a bad switch. First turn and nothing happened. Turn back and cannot turn again. Now I cannot turn, and it had not rained at all since the last use. Anyone have any input on how hard it os to replace on an '81 KZ550? Thanks
1981 KZ550 A2
  • gte105u
05 Jun 2010 08:44
#373627
Found a NOS one with helmet and seat lock for $95. Is that worth it? More than I wanted to spend but NOS does cost more. It will be nice to have all the locks keyed the same too.
1981 KZ550 A2
