Poor running Z1B
- nysz1b
Poor running Z1B
02 Jun 2010 19:45
Hi all,
I have a '75 Z1-B, with a "Dyna S" ignition installed, (stock coils). Starts/idles fine, but is down on power; acting as if timing is not advancing. Just did a valve & ring job,cam timing is spot-on, carbs are clean & synced. When Dyna S was installed, timing was set with timing light.
Took for 50-mile road test, and as noted, is down on power; just doesn't have the "snap" that should be there. Did not exceed 5K rpm )or so) for break-in purposes. Airbox is stock, as are mufflers. Any suggestions? Thanks in advance!
- timebomb33
Re: Poor running Z1B
02 Jun 2010 19:48
pull your advancer of and see if its working properly make sure it's moving freely on the bolt.
I THINK MY POWERBAND BROKE
- nysz1b
02 Jun 2010 19:51
I cleaned and lightly lubed the advance when Dyna-S was installed, but will check it again. Thanks!
02 Jun 2010 20:57
Would assure all four cylinders are combusting by spraying water mist over exhaust headers while engine idles, to see if water instantly vaporizes off every header.
