Drum Roll..............................Nothing
  • jonnygorman
  • jonnygorman's Avatar Topic Author
27 May 2010 20:10
#371537
I changed the handle bars on my bike and with all back together I went to start it and..........nothing. Zilch. All plugs are together and battery has twelve volts, all lights work and I have 12 volts to the run/off switch. I tried to check voltage with the start button depressed but had a hard time making contact with meter probes............ Any ideas? The bike has never had a problem starting and before my tinkering worked fine.
Thanks
Jon
  • MFolks
  • MFolks's Avatar
Re: Drum Roll..............................Nothing
27 May 2010 20:15
#371539
Open up the switch pods on the handlebars looking for pinched wires or bad grounds. Checked inside the headlight housing for loose/disconnected wiring? Any fuses blown?
  • djturnz
  • djturnz's Avatar
28 May 2010 03:59
#371590
Does it turn over but not start, or nothing at all when you push the button?
If nothing at all, check the clutch safety switch (if you have one). I broke a wire on mine when I changed my bars over. I ended up bypassing it at the harness.
1982 KZ750 (4) LTD
  • Old Man Rock
  • Old Man Rock's Avatar
28 May 2010 05:46 - 28 May 2010 05:54
#371608
Kill switch...
The same ignition switch output (brown conductor) feeds the lighting as well....
You have lights but no power/battery voltage being delivered to the starter/kill switch/coils.
Not sure of your Kawi but should be similar where the handle bar is normally chassis/battery ground potential....
With the kill/run switch activated, grounds out the power to the starter & coils....
For the KZ900 as example...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 28 May 2010 05:54 by Old Man Rock.
