diff in dyna s
  • 77KZ650
  • 77KZ650's Avatar Topic Author
diff in dyna s
05 Apr 2006 21:09
#37121
Just wondering, what is the difference between the dyna s for the 550, 650, 750, and the one for the 900, 1000?
(DS2-2 vs DS2-1)
Scott
07 MDP Rookie of the Year
  • loudhvx
  • loudhvx's Avatar
Re: diff in dyna s
05 Apr 2006 22:34
#37142
The 550, 650, 750/4 should be the same.
The 900/1000 family use a larger physical plate, and the rotor may be slightly different.
Electrically, I don't think there is any difference. There would be no reason for any electrical difference, but I don't know for sure.
  • 77KZ650
Re: diff in dyna s
05 Apr 2006 23:00
#37145
I thought it must be something like that, on the dynatech site, they use the same pic and instructions for both versions. I cant see there being a reason for them to be different electrically either, they both use the 3.0 ohm coils.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: diff in dyna s
06 Apr 2006 04:52
#37170
It is basically the size. The KZ650's have an additional wire for the oil pressure switch - the base unit is similar, but it's not something you could easily adapt to swap between the 900/1000 version and the 550/650/750 version.
