voltage fluctuation on 1981 CSR 1000
- 1981jmotor
- shade tree mechanic
22 May 2010 23:00
Hey Riders, when my bike is idling, there is a noticeable voltage fluctuation of my lights. Also, I know I may need to adjust it, but my horn will not blow at idle.
My bike has been out in the weather some in its 29 years.
Is the fluctuation normal as the regulator and alternator are not steady voltage supplies at idle?
I have a real strong battery. If there are weak connections somewhere, could that cause the horn issue /voltage fluctuation? Like maybe some of the fuses and holders need to be cleaned?
David M.
Norman, OK
1981 Kaw CSR 1000
David M.
Norman, OK
1981 Kaw CSR 1000
1981 Kawasaki CSR 1000
First bike ever at 14 years old was 1969 Honda CL 175.
Bought a brand new Honda CM400T at 16 years old in 1979.
- bountyhunter
Re: voltage fluctuation on 1981 CSR 1000
22 May 2010 23:14 - 22 May 2010 23:15
I would always see headlight flicker at idle on my old plymouth. You will see some AC ripple at low RPM. I think as long as you have a steady 14V when the revs go above about 3K, your reg is probably working OK.
Last edit: 22 May 2010 23:15 by bountyhunter.
23 May 2010 04:34
1981jmotor wrote:
But maybe not strong enough.
Would have battery load tested.
Could test by jumping to known good car battery (car engine NOT running). Try sounding bike horn with bike engine not running (ignition switch in ON position) and again at idle.
If bike horn blows at idle with jump, but doesn't blow absent jump, the bike battery likely isn't up to snuff for whatever reason. Would check fluid levels and specific gravity (with little floating balls eye-dropper gadget), and re-charge.
... horn will not blow at idle...have a real strong battery....
23 May 2010 04:38Dyna-S is known to consume more power than oem ignition, especially at idle.
- otakar
23 May 2010 05:03 - 23 May 2010 05:04
I have the EXACT electrical you have and I have a steady 14V at ALL RPM ranges. From idle on up. My battery is 3 years old.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 23 May 2010 05:04 by otakar.
