dyna electronic ignition
  • rob220
  • rob220's Avatar Topic Author
Re: dyna electronic ignition
23 May 2010 08:07
#370096
It would be 1 and 4 that are not firing. Both electronic ignitions did something different but with the same cylinders.
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
23 May 2010 08:45
#370104
That would relate to the Dyna-S module on the left-hand side or 9 o'clock position, and the black wire from there to the left-side ignition coil which has plug wires attached to outside cylinders #1 and #4.
:unsure: What was different about behavior between the two electronic ignitions?
Good Fortune! :)
  • rob220
23 May 2010 09:13
#370122
On the first one the 1 and 4 side it I hook it up to the coil I will get a spark as if I'm grounding it out. The wires begin to get hot. The second one will give me power through both wires(constant). I'm gonna wire the second one on a different bike and see if it is still working. The first one did the same thing on a different bike. The second one worked fine on a different bike before I put it on my bike and worked fine on my bike for a brief moment.
1075kit
suzuki tl1000 rim
  • rob220
23 May 2010 09:17
#370126
Good Fortune! :)
On mine I have the white going to 1 and 4 and the black going to 2 and 3. Would that make a difference as long as I have the coils going to the right cylinder?
1075kit
suzuki tl1000 rim
