73 Z1 blue wiure from rear turn signals ????
- mtkawboy
21 May 2010 11:12
Trying to hook up the rear turn signals on my 73 Z1. Theres a blue wire coming from both of the rear turn signals with male ends on both & nothing to plug them into. Im not very good at wiring diagrams. It shows on the diagram a blue wire going from the brake lite switch which there is but what do you do with the 2 blue wires from the turn signals ??
- MFolks
Re: 73 Z1 blue wiure from rear turn signals ????
21 May 2010 11:54
I'm not sure of the earlier Kawasaki's wiring colors, but the wire colors of later ones are like this:
BLACK with YELLOW stripe, the ground circuit.
RED,the tail light or running light.
BLUE(sometimes with a RED stripe) the brake light circuit.
- rstnick
21 May 2010 11:57
Sounds like you have 3 wire, with dual filment bulbs, signals.
The front turn signals on some models have 3 wire dual filament bulbed turn signals, which have running lights as well as signals.
The blue wire is for the running light circuit.
Sounds like someone added front signals to the back of your bike.
If you run a wire from the front signal blue wire to the back blues, you can have running lights all the way around, front & back.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
