dyna ignition
  • irish mike
  • irish mike's Avatar Topic Author
  • 79 kz 650 b3 rat rod
dyna ignition
15 May 2010 12:02
#368123
hi all i finally got enough cash for my dyna ignition-ive already installed the dyna coils and plug wires[didnt think id come up with the money for a while]how much of a pita is it to install [coils and wires were a piece of cake]do i still need a timing light to set timing the first time -any advice much appreciated ..thanks in advance mike.....
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: dyna ignition
15 May 2010 14:27
#368138
should be another piece of cake.
just follow the instructions.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
  • Old Man Rock's Avatar
Re: dyna ignition
15 May 2010 15:17
#368143
Have to modify the coil mounts slightly... not a big deal, can even use stock pieces....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
Re: dyna ignition
15 May 2010 15:20
#368144
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Kawickrice
  • Kawickrice's Avatar
Re: dyna ignition
15 May 2010 20:01
#368192
Dont sweat not having a timing light. If you set the timing dead nuts statically 9 times out of 10 the strobe will be the same. The instructions can be confusing. If you are familiar with setting the points treat it the same as far as the "F" mark lining up when she fires. The instructions tell you to hold the advance and fire on the "T" mark. As long as the advance works right you should have no problems.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
