fumes from carbs
  • bullitt
  • bullitt's Avatar Topic Author
fumes from carbs
12 May 2010 11:07
#367454
hi i can smell petrol around my carbs
i have pods on, where my carb bowl drain tubes are
if i look at them( i have no tubes on them) you can
see petrol fumes coming out is this normal
theres no dripping petrol anywhere i"ve always thought
i use a bit to much fuel can worn float needles cause
this and i still get awhite residue on oil filler cap
bike runs fine though
cheers dave
  • Turtle
  • Turtle's Avatar
Re: fumes from carbs
12 May 2010 18:46
#367564
Does it mis-fire? Could be raw fuel mixing with the oil causing the white residue, I know water and oil make a milky looking oil. Maybe somone else can elaborate.
You probably will see some fumes with no vent tubes.
1980 KZ 1000 A4 with 750 Zephyr swing arm and ZX-9 rear wheel
