spark plug caps
  • Kawboy74
  • Kawboy74's Avatar Topic Author
spark plug caps
11 May 2010 17:59
#367325
Hello I am building a '74 Z1 and am doing a little bit of forward research. I have a set of 3 ohm Dyna coils with the Dyna pickup purchased for the build. I also bought a set of Dyna wires but would like to incorporate NGK plug caps. The problem I see is there are basically two types of boots that are identical other than one set has 1 ohm resistance and the other has five ohm resistance.I seem to remember that the resistance had a lot to do with radio interference which is not a concern so should I try to see what the original cap rating was or is it not an issue? Obviously the dyna coils will perform better and produce a hotter spark but doesn't plug gap play more of a role in this area? Any and all advice would be greatly appreciated.
Thanks David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • hocbj23
  • hocbj23's Avatar
Re: spark plug caps
11 May 2010 19:11
#367340
There are some posts here from otakar and others that go into the plug gap issue with aftermarket ignitions. I have an 82 CSR with the J motor with a Dyna S and 3 ohm Green Dyna coils and am running Taylor 8mm wires, the stock NGK plugs but with a .40 gap and my bike runs fine all the way up to rev limiter.Some folks are running as hi as a .60 gap.Depends on ur coils and ignition. I am sure others will weigh in with opinions.bj
  • hocbj23
  • hocbj23's Avatar
Re: spark plug caps
11 May 2010 19:15
#367341
Sorry..040 gap not .40.bj
  • bountyhunter
  • bountyhunter's Avatar
Re: spark plug caps
11 May 2010 19:48 - 11 May 2010 19:51
#367349
Thanks David
Five Ohms of cap resistance is negligible, since it is in series with an air gap which is many millions of Ohms. I thought spark plug resistor wires were a lot higher like 10k Ohms to kill EMI radiation (from ringing). Five Ohms is totally negligible.
Last edit: 11 May 2010 19:51 by bountyhunter.
