Ignition Wires and coil
- jseagraves
04 Apr 2006 14:54
I am making a large purchase from Z1 tonight and the last thing I need to figure out (without the manual) is what size ignition wires and what type caps I need to get? Does anyone know? and what about coils is there specs on those that I should know about?
Thanks
Thanks
- jseagraves
- Sandy
- Fly High,Tony
Re: Ignition Wires and coil
04 Apr 2006 22:51
You'd be better off just asking Jeff(Z1)before You finalize the shipping process...just to be sure.He'll help You figure out what all You're going to need.
Unless of course,Someone jumps in here tonight,and helps You out.
1977 KZ1000 A-1
- KitNYC
04 Apr 2006 23:15
I'm assuming from the fact that the copper wires Z1 sells only come in 7mm that that's the size you need. I'm also assuming that the plug caps that come with the wires will work for you. I could be wrong about that, but I'm pretty sure your bike has a mechanical advance & therefore uses the copper wires.
Really, though, your best bet is to place your order by phone & ask Jeff which ones you need.
Cheers,
-Kit
Cheers,
-Kit
- BARNEYHYPHEN
06 Apr 2006 14:50
Must I use copper plug wires if I have a mechanical advance? I'm using Accel graphite 8.8mm wires with non resistor plugs, non resistor caps, with a Dyna S.
Should I be using copper?
- Biquetoast
- King Jeremy The Wicked
06 Apr 2006 14:54
jseagraves wrote:
I just bought a coil and wires from Jeff@z1enterprises.com.
I just emailed him, and he and I went back and forth a few emails about the specifics, and I ordered the correct one with confidence.
Does anyone know how I can find out?
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
