Timing Plate
- gremlin497
06 May 2010 16:38 #366001
by gremlin497
1977 KZ 1075 (FBG), 29 Smoothbores V&H Mega
Timing Plate was created by gremlin497
Guy i screwed up. When took my motor to get done, I took off timing plate and didnt mark it. Can some ou there give me a good start placement for the timing plate do i can put timing gun on it, and then work on getting carbs synced.
- Old Man Rock
- Thank you received: 225
06 May 2010 16:43 #366007
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Timing Plate
Would kind of help if you could supply which bike your speaking of..... :whistle:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- gremlin497
06 May 2010 17:20 #366018
by gremlin497
- bountyhunter
- Thank you received: 337
06 May 2010 17:41 - 06 May 2010 17:41 #366023
by bountyhunter
Replied by bountyhunter on topic Timing Plate
I would try this:
1) Look really close at the plate and see if you can detect the wear marks in the plate surface from where the "hold" screws crank down against it.
2) If not #1, set the plate with the screws midway in the elongated slots. Should be close enough to start.
Last edit: 06 May 2010 17:41 by bountyhunter.
- Old Man Rock
06 May 2010 18:59 #366054
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The 1976 KZ900 and early KZ1000 would be very similar... I believe anyways...
Anyhoot, this was the image I took on my KZ900 pre Dyna ignition installation... The bike would start but I didn't do much other than that for I wanted EI from the get go....
Maybe helps, maybe not....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- gremlin497
06 May 2010 19:45 #366077
by gremlin497
Replied by gremlin497 on topic Timing Plate
Thx, but no help. Hvae electric ignition. Points have long been gone from bike.
- Old Man Rock
06 May 2010 19:58 #366080
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Ok.......... Could have mentioned that little tid bit of info as well.... :whistle:
Ok, is it a Dyna Ignition? :laugh:
Considering EI then no brainer.... Set theplate where 3 mounting screws are half way between moon shaped slots....
Then in timing light, idle ~ 800-1000 OEM spec but possibly 1000-1300 on yours.... for "F" mark alignment.... Rev throttle and hold at 2500 rpm for Advance Mark alignment...
Bottom line, if you had the pickups/sensors aligned already, then you should just have to rotate the plate for F/T & Advance marks...
In theory anyways without knowing all that was being accomplished where the plate required removal.... With that said, may want to go through the Static alignments first just to insure all is good...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- jeffasaki
- Thank you received: 44
07 May 2010 04:27 #366124
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic Timing Plate
Nice pic of them old points.Reminds me of when my furniture was made of sticks and mud.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- gremlin497
07 May 2010 04:41 #366129
by gremlin497
