starter issues!!!
  • Kawiman80
  • Kawiman80's Avatar Topic Author
  • On my 2nd KZ1000
starter issues!!!
05 May 2010 09:51 - 05 May 2010 10:06
#365709
Hey guys,
I need your input. I have a hard time starting with my starter. I will crank and crank and then stop,like a clunking sound and then crank again, with the choke on,but no starting. I got good spark,battery is good. But after all that,one good kick and she's running. The starter sounds like it is dragging,but when you just open the throttle,it spins just fine. I have checked everything. iam at a loss. PLEASE HELP!!!
Thanks,
Mike
If i need to rebuild my starter,where can I find akit? i've looked on ebay already and found some for 81 and up.
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
Last edit: 05 May 2010 10:06 by Kawiman80. Reason: updated question
  • Kawickrice
  • Kawickrice's Avatar
Re: starter issues!!!
05 May 2010 10:13
#365712
Sounds just like the symptoms my KZ650 had. Dyna ignition, dyna coils, and rejetting cured it for good. Starts the first time now. I see from your signiture you already have ignition and coils. Are you running lean on your jetting?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • MFolks
  • MFolks's Avatar
05 May 2010 14:07
#365771
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
05 May 2010 14:38
#365779
I'd say take that starter completely apart and do a proper rebuild.
Its fast and easy, and makes a huge improvement.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • MFolks
  • MFolks's Avatar
05 May 2010 15:09
#365788
Check with the local electrical motor rebuilding places, most cities have them.
05 May 2010 16:41 - 05 May 2010 16:42
#365812
Kawiman80 wrote:
...hard time starting with my starter. I will crank and crank and then stop,like a clunking sound and then crank again, with the choke on,but no starting. I got good spark, battery is good. But after all that,one good kick and she's running. The starter sounds like it is dragging, but when you just open the throttle, it spins just fine....
battery is good --- but not good enough. :lol:
after all that, one good kick and she's running --- electric starter is drawing current otherwise available to ignition. Kick starter sends more current to ignition without wasting most of it through the electric starter.
starter sounds like it is dragging, but when you just open the throttle,it spins just fine --- regardless of starter (kick or electric), when cranking a cold engine with choke applied, remember not to touch the throttle, as enrichener systems are designed to best function when all carb slides are fully down.
Good Fortune! :)
Last edit: 05 May 2010 16:42 by Patton.
  • Kawiman80
  • On my 2nd KZ1000
24 May 2010 23:43
#370693
Sorry it took so long to get back. Damn computer crashed and had to get it medicated!!! Damn viruses. Anyway,I talked to my local mechanic and he recommends rebuildin the starter,and makin sure the battery hasn'nt lost a cell in it. Then look into the stater clutch.It maybe going bad.
Patton,I was refering to when I open the throttle,it's not on the choke.
Next,it will start of a my truck battery,with the starter button. I looked into getting a battery from FBG,made for high copression drag bikes,but at 130 -160 bucks,a little out the budget.
I was looking on Dragbike.com an came accross an ad for rebuilt starters. It's Paul Cashio Engineering. The rebuild starter for any classof racing.
Has anyone haad aything done by him? How good is the quality and any warranty?
Thanks for all the info.It is greatly appreciated.
Mike
