Timing Marks Help
- Clearwind
01 May 2010 15:03 #364764
by Clearwind
Timing Marks Help was created by Clearwind
Hey guys,
I've got a question about the timing marks and need help understanding what each of the marks is for. The following 2 pictures show the marks that I am talking about. Going clockwise around the "Mark wheel??" I see a T with a mark directly to it's right, followed by an F with a mark to its right, then 2 3 with 2 marks imediatly after it.
Could someone explain what the marks indicate?
- Clearwind
01 May 2010 15:04 #364765
by Clearwind
Replied by Clearwind on topic Timing Marks Help
- TeK9iNe
- What did you do!?!
- Thank you received: 28
01 May 2010 15:31 - 01 May 2010 15:33 #364768
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Timing Marks Help
The T mark is TopDeadCentre.
The F mark is the Fire mark (where the plug fires @ 10 degrees advanced @ idle.)
The 2 small marks afterwards are the full advance indicators. For cylinders 2 + 3 in this case.
With the engine above 4000rpm (full advance),the case mark should fall between those two marks, with a timing light.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 01 May 2010 15:33 by TeK9iNe.
- Clearwind
01 May 2010 16:37 #364781
by Clearwind
Awesome thanks a lot. One problem down. Many to go.
