Custom Turn Signals
  • Fozzie
  • Fozzie's Avatar Topic Author
Custom Turn Signals
27 Apr 2010 19:26
#363712
I've been thinking about making custom turn signals on the back using some pretty cool lights I've found on ebay. Has anyone else taken on a project like this? Any problems? Pics would be awesome, thanks guys.
1982 KZ1000J
  • bountyhunter
  • bountyhunter's Avatar
Re: Custom Turn Signals
27 Apr 2010 19:36
#363719
Check the local laws. The lights have to be a certain minimum distance away from the center of the brake light lense to the left or right (I think it's 8" in California). Don't give the cops any excuse to pull you over.
  • MFolks
  • MFolks's Avatar
27 Apr 2010 20:10
#363735
If you go with LED signals, I doubt if the lamp current will be enough to make the signal flasher to work unless you change it to an electronic one.
  • Fozzie
28 Apr 2010 15:32
#363909
Yeah, one of the things I was thinking about was the distance between the lights, but I didn't know there were any laws. Something to research for NC. And as far as LED's go, what would I have to do? Switch to electronic? Explain please.
1982 KZ1000J
  • MFolks
  • MFolks's Avatar
28 Apr 2010 15:37
#363910
You'd have to replace the silver flasher can with an electronic one. I believe most auto parts stores carry them. They are supposed to be able to compensate for LED or regular bulbs.
  • Mark Wing
  • Mark Wing's Avatar
28 Apr 2010 20:20
#364030
Here's what I run for blinkers on my 650, this is the right turn light. I live in Cal. and the cops don't say anything about spacing. I've had a couple cops say where's your rear turn lights and I turn them on and they say cool.
Mark
Yorba Linda Cal.
  • bountyhunter
28 Apr 2010 20:27
#364032
I have seen posts from guys who integrated the TS lights into the brake light assembly and got written up for it (it was posted on other bike forums). Somebody posted the VC about it and I recall it was eight inches off center, I know it's too close if they are all the same lamp. Local cops may not care, the CHP are the guys who are supposed to know all the stuff.
  • djturnz
  • djturnz's Avatar
29 Apr 2010 03:56
#364051
I would think you could also add a resistor to the circuit to make the flasher work. Don't know the value or specs needed offhand though.
1982 KZ750 (4) LTD
  • sabell
  • sabell's Avatar
29 Apr 2010 05:39
#364068
Rather then adding resistor IMHO it's easier to just get the electronic flasher at the auto parts store for about $12. Mark Wing, what did you use to block off the midddle of your light to keep it from bleeding over to the other side?
'78 KZ1000A2
'79 650SR
  • Mark Wing
29 Apr 2010 08:57
#364113
I didn't use anything, the reflector is shaped to only let light come out on separate sides. So far the CHP Orange and Anaheim police have let it slide, besides I know a cop that will sign it off.
Mark
Yorba Linda Cal.
  • sabell
  • sabell's Avatar
29 Jun 2010 20:40
#379113
Had to steal your idea Mark...never cared for turn signals much, but your way kills 2 birds with 1 stone.
'78 KZ1000A2
'79 650SR
  • trianglelaguna
  • trianglelaguna's Avatar
29 Jun 2010 22:06 - 29 Jun 2010 22:13
#379143
No eBay APP ID and/or Cert ID defined in Kunena configurationi used these small black with orange lens ones and they pretty much disapear...i never leave my turn signals hooked up for my own saftey reasons ...but they were bright as hell and are super low profile.....
the stems on the little light kits are not long enough for the headlight brackets and washers and nuts...the tail light set were just barely long enough....
here's what i did...i double nutted the aftermarket lights shank and backed it outta the little plastic light housing ...then i ran to a hardware store and got their longest all thread lamp electric deal (2-3") and used those with two nuts screwed em 1 " into the turn signal after feeding the lights wires through the hollow all threads deals....i did twist one signals wires free...the next time i was very slow and extra careful with the tiny wires and the shitty solder points,and they fabbed up fine...i double nutted them inside the headlight bucket and the tail sections mount holes and they stayed put....2 yrs and i forget they are even there...they will however really light the intersection up ...if hooked up ...and i would give em a 10, actually a 11, just bgecause they are only a few bucks a set.....the hardware store lamp poles centers were extra and ran like 2-3 a piece too.....good luck....this is the way i will do all my bikes now...it is low profile and blends against the frame imo....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 29 Jun 2010 22:13 by trianglelaguna.
