no spark on 2&3
- GP550kz
no spark on 2&3
02 Apr 2006 20:09
Let me start by saying this website is great.It's so full of usefull info. Ok ihave an 81 550kz with spark on 1&4 no spark on 2&3.I have checked all wires caps and coils.Ialso checked the igniter with a test I found here.acording to the test my ignitor is bad.Just wanted some feedback before spending the money Thanks in advance. George OKC.Oh by the way I've read every arcive on this subject With no luck.
- loudhvx
Re: no spark on 2&3
02 Apr 2006 22:41
So if you swap the green and black wires at the coils, you get no spark on 1&4?
Then put the wires back on the correct coils.
Then if you swap the pickup wires (using jumpers): black with yellow and red with blue, you still get no spark on 2&3 (still sparks on 1&4)?
Then yes, sounds like the ignitor is toast (or there is a broken (green) wire from ignitor to coils.
If you can't find one on ebay, you could try to make one:
www.geocities.com/loudgpz/GPZgmHEImod.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wiredgeorge
Re: no spark on 2&3
03 Apr 2006 05:47
George, Bit of clarification... the pickup coils are the two black boxes set around your crank end under the points cover. The one on the left is the 1/4 pickup coil and the one on the right is the 2/3.
Since you have no spark on 2/3, the symptom points to a common cause for BOTH cylinders not firing. This will be either the pickup coil or ignition coil.
The easiest FIRST step is to check the ignition coil (2/3). As loudvhx pointed out, the green wire is associated with the 2/3 side. It comes off the pickup coil and goes into the igniter box. It comes out and attaches to the 2/3 coil. Pull the black wire off the 1/4 coil and put the 2/3 green wire on this coil and connect the 1/4 black wire to what had been the 2/3 coil. Check for spark since you have effectively sent the 2/3 signal info to the other (GOOD) coil and see if you have spark. If you do have spark, then the other coil is bad. If you DO NOT have spark, you may have a bad pickup coil and further testing will need to be done.
- ran429
- Master of FREE rides!
Re: no spark on 2&3
03 Apr 2006 08:17
I am having the identical issue with my bike, replace the pickup coils under the timing cover.
start it once, while running it jiggle the red & yellow wires at the timing cover. if the idle changes you have found the short.
the yellow wire on mine took a dump.
- GP550kz
Re: no spark on 2&3
04 Apr 2006 19:09
I went and bought a used ic ignitor today and slapped it on .My bike fired right up and sounded great .took it for a test drive for the first time on four cylinders and was shocked by the quickness.when I bought the bike it had not ran in ten years.best 500 dollars I ever spent .Thanks for all the advise. George
- loudhvx
Re: no spark on 2&3
04 Apr 2006 20:31
I hope you mean $500 for the bike and not the ignitor
1981 KZ550 D1 gpz.
Other links.
Other links.
- GP550kz
Re: no spark on 2&3
04 Apr 2006 20:52
Yea 500 for the bike 60$ for the igniter. Also I just ordered pod filters and a stage 3 jet kit. Dudes I'm so stoked!!!!!
- ran429
Re: no spark on 2&3
05 Apr 2006 00:58
Hmm, maybe I too will change igniters tomorrow. hen I can have a spare pulse generator coil pickup set when they come in.:whistle:
- OKC_Kent
Re: no spark on 2&3
05 Apr 2006 10:36
George,
Check your PM messages.
Kent
Kent
Cashion, OK
78 KZ650 B2 85,000+ miles
