WG Coil Mod — 10A inline fuse blows prematurely
  • otakar
  • otakar's Avatar
Re: WG Coil Mod — 10A inline fuse blows prematurely
26 Apr 2010 10:36
#363285
If your ignition requires any more than 6 Amps, you have some really major problems. a 10A fuse should NEVER blow on your properly working ignition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • 893cv
  • 893cv's Avatar
26 Apr 2010 10:50
#363286
The Dyna S system does draw more power then the stock system, even more so if the Dyna coils are used. I think the draw is right up at 10 amps, thats why I use a 20 amp fuse to power the system on my KZ.
1980 kz1000 LTD
1978 Z1R
  • otakar
  • otakar's Avatar
26 Apr 2010 11:16
#363291
I talked to Dyna and with their 3Ohm coils under MAX load the system should peek at a max of 6A If you are using the 2.2Ohm coils it will draw 8.2A max but will burn the coils after a given amount of time. The 2.2Ohm coils should only be used for Drag racing which has short run times.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • alexnelson
  • alexnelson's Avatar Topic Author
17 May 2010 11:08
#368529
Been a while since I posted to this thread but I just noticed all these replies that I wasn't notified about.
The latest news: I ditched the coil mod and now have a perfectly functional motorcycle. I couldn't ask for more. You guys have been a huge help. Never had to see a mechanic once.
F$#@ing awesome.
78 KZ650-D1
K&N pods + 4-1 Pipe
Mikuni VM24 - 7.5/115/#4 Clip
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
