Ignition or fuses?
- LTD
Ignition or fuses?
02 Apr 2006 19:49
My tail light will not work and if I turn the key to the third position on the ignition my bike shuts off. SO would the problem be in the ignition or the fuses?
- wireman
Re: Ignition or fuses?
02 Apr 2006 19:52
third position is probably park light.check fuse and bulb.
- LTD
- loudhvx
02 Apr 2006 19:55
I think there should only be one position where your bike runs.
There's "off", "run", and "off with tail light on" as a parking light.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Sandy
- Fly High,Tony
02 Apr 2006 22:13
loudhvx wrote:
Yip...same as My bike.
LTD...does Your taillight come on with the key in the third position?I'm thinking not,if it's not coming on in the "Run" position,but thought We had better narrow that down,to rule out the bulb,but like mentioned...check the bulb AND the fuse.You should have 3 fuses in Your fusebox(main,head,and tail).
Good luck and let Us know whatYou find.
1977 KZ1000 A-1
