77 kz650 turn signal problem
- ckotul
1977 KZ650C1
- bountyhunter
- Thank you received: 337
- MFolks
- Thank you received: 540
On the rear signals, #1156 single filiment bulbs are used.
#1157 is also used in the brake/tail light circuit.
- ckotul
1977 KZ650C1
- MFolks
- patmann
- Thank you received: 6
I had some small amounts of rust/corrosion inside the bulb socket.
Use fine sandpaper INSIDE the socket and wiggle the bulb a bit until it gets good contact and works as it should.
Again, As I remember it that is what I did to fix my problem.
Could be wrong, could be right
Regards, Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
I too had this problem a few years ago. As I remember it ..
Regards, Pat
This is a new light there should be no corrosion.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- ckotul
1977 KZ650C1
