Main fuse blowing with turn signals
- rnuse
- Balls to the walls, sideways all the time
21 Apr 2010 21:36 #362243
by rnuse
1982 kz750 ltd
Drag bars, 4into1 V&H with no baffle.
1991 zephyr 550
about to give up on her.
Main fuse blowing with turn signals was created by rnuse
Description says it all^
Odd thing is, the fuel light was flashing umtil 3 seconds later it all went dead. So if they are shorted together.... Where?? I cant see anything. I haven't tore it down yet though.
Kicker: I have to take my exam tomorrow to get my license. Otherwise, I would use hand signals.
1982 kz750 ltd
1991 zephyr 550
- MFolks
- Thank you received: 540
21 Apr 2010 22:10 #362250
by MFolks
Replied by MFolks on topic Main fuse blowing with turn signals
I'd check the four bulbs and see if a filiment has broken and touching inside one of them.
I believe if your bike has front running lights in the turn signals that they will be #1157,with the rear ones #1156.
#1157 is also used in the rear brake and running(tail light) circuit.
Possible insulation damage can also cause fuses to blow.
- bountyhunter
- Thank you received: 337
21 Apr 2010 23:10 - 21 Apr 2010 23:13 #362253
by bountyhunter
Replied by bountyhunter on topic Main fuse blowing with turn signals
Be sure to replace with a new fuse. Old fuses sometimes blow way below rating.
Turn signals are notorious for blowing fuses because the wires run in and make a right angle turn and can easily rub through the insulation and create an intermittent short.
Last edit: 21 Apr 2010 23:13 by bountyhunter.
- anyday
22 Apr 2010 04:48 #362271
by anyday
1981 KZ 1000-k, 1982 GS300L-D, 1982 GS300L-Z (parts)
Sioux City, IA
Replied by anyday on topic Main fuse blowing with turn signals
Check your leads under the seat - I had the same thing happen about a month ago. One of the orange signal leads and the large white main ignition wire were crushed in the seat latch and then shorted on each other.
Sioux City, IA
- rnuse
22 Apr 2010 06:42 #362299
by rnuse
1982 kz750 ltd
1991 zephyr 550
Replied by rnuse on topic Main fuse blowing with turn signals
Thats what happened. My seat pinched the wires and grounded a hot wire. Thanks all!
1982 kz750 ltd
1991 zephyr 550
