MAJOR electrical problems on my 1977 kz650
- neh810
neh810@yahoo.com
- bountyhunter
- Thank you received: 337
If yu see indicators dim when you turn something on, that something is drawing a ton of current.
when my lights are turned on,and i turn the kill switch on,my turn signal lights turn a dimmer color.
Wild guess, but I would look at the coils or the wiring to them for a short of some kind.
- MFolks
- Thank you received: 540
Some websites for stators/ regulator/rectifiers:
www.rmstator.com
www.electrosport.com (This website has a troubleshooting page)
www.customrewind.com
www.regulatorrectifier.com
www.ricksmotorsportselectrics.com
www.oregonmotorcycleparts.com
- jeffkz650
- bountyhunter
- MFolks
Any excess energy was converted to heat, disappated(sp) through the cooling fins.
There is/was no fuses on the charging system.
- jeffasaki
- Thank you received: 44
pull the dive gear cover and have a look99% sure this is wherew the problem is.FAMOUS SHORT on these bikes
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
PS get a dyna S way better idea
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- neh810
(2)where on the bike do i look to find that part and area ?
- RetroRiceRocketRider
- Thank you received: 29
You didn't mention if you'd done anything to your bike prior to this happening.
Normally grounding out issues don't "just happen", there's usually something (most times something minimal) that caused it, ie: repositioning the switches on the h-bars, adjusting the headlight angle, moving the wire harness to get to the air filter, etc.
I had a similar issue a few years back on my '78 650. It turns out that when I replaced the OEM handlebars with some SuperBike bars I had placed the switches directly against the clutch and brake perches, therefore pinching the wires slightly. Eventually it wore through the wire insulation and----pow! Blown main fuse and HOT main wire to fuse box.
- neh810
