voltage regulator-kz650
  • irish mike
  • irish mike's Avatar Topic Author
  • 79 kz 650 b3 rat rod
18 Apr 2010 12:12
#361483
hi all iwas piddling around with my bike today and found that the voltage regulator was very hot im presuming this is not normal -if not any ideas on what the problem might be?thanks in advance mike......
  • fixer5000
  • fixer5000's Avatar
Re: voltage regulator-kz650
18 Apr 2010 13:01
#361493
it might not hurt to unplug and clean all the bullet connectors going to it. heat means resistance usualy. im not too sure if they run hot either. could be normal. someone else will chime in here soon im sure...good luck
1978 kz650b pretty much stock
massachusetts
  • MFolks
  • MFolks's Avatar
18 Apr 2010 15:57
#361512
Any excess energy is vented via the cooling fins of the regulator/rectifiers.Some are mounted under the battery box, others on the side.
The bike's with the magnetic rotors have alternators that run wide open, with the regulator/rectifiers controlling the battery charge and running the electrical system.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
18 Apr 2010 18:00
#361540
Yes, they can get serious hot, enough to burn you after spirited long rides.
Like MFolks said, its waste energy from the charging system keeping things at less than 15V.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
