1980 Kawasaki KZ550 fuse assembly
- mbethel
18 Apr 2010 11:59 #361477
by mbethel
1980 Kawasaki KZ550 fuse assembly was created by mbethel
Does anyone have an idea as to where I can get a fuse assembly for a 1980 KZ550 A1? I had an electrical fire last year and this is the only part left that is keeping me from riding!
- MFolks
- Thank you received: 540
18 Apr 2010 12:05 #361479
by MFolks
Replied by MFolks on topic 1980 Kawasaki KZ550 fuse assembly
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1†long. Most good auto parts stores can get them for you. They are ¼†in diameter.
2. The more common AGC is 1 ¼†long and may not fit the smaller fuse clips. Again, ¼†in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade†style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini†Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade†style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net www.delcity.net/cartviewitem?item=73805&search=y You'll have to do some electrical wiring to make the "Blade Style" fuse holder work, but it's the type used in cars and the newer bikes.
- polkat
- Thank you received: 1
18 Apr 2010 12:07 #361480
by polkat
Replied by polkat on topic 1980 Kawasaki KZ550 fuse assembly
Many of us have switched over to a blade type fuse box. You can get them most anywhere (even Radio Shack), and they eliminate a number of problems the old glass fuses had. If you want to keep it stock you might try the Old Bike Barn or Z1 (maybe?).
