Quick Q - What is this switch?
- jordash
17 Apr 2010 14:40 - 17 Apr 2010 14:47
Alright, I've flipped it back and forth, running, signals, brights, in gear... and as far as i can tell it does nothing.
This is a 1982 750 Spectre, stock as far as I know.
Oh, my first post. Hi all, and thanks.
'08 KLR650
'82 KZ(Z)750 Spectre
In Denver, CO - Seeking nomad's land
Last edit: 17 Apr 2010 14:47 by jordash.
- Mcdroid
- Gone Kwackers
Re: Quick Q - What is this switch?
17 Apr 2010 14:57
Welcome!...and it is the hazard switch.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Motor Head
17 Apr 2010 14:57
I think it turns the automatic turn signal function on and off.
- jeffasaki
17 Apr 2010 15:20
That switch injects dylithium crystals into the float bowls to engage warp drive:laugh: :laugh:
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- TeK9iNe
- What did you do!?!
17 Apr 2010 15:46
STOP!.
Put away the bike.
Pick up the manual.
:laugh: :laugh: :laugh:
Yes, its supposed to be a hazard switch that blinks all the signal indicators at once.
Put away the bike.
Pick up the manual.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JMKZHI
Last edit: 17 Apr 2010 18:26 by JMKZHI.
- MFolks
17 Apr 2010 18:59
Under the seat, close to the battery,should be two small silver cans(flasher relays) one controls the turn signals, the other the 4 way hazard lights.
I'd suggest replacing both as they may be worn out/failed.
Most auto parts stores sell them, some with three prongs, others with two prongs(electrical connections).
I believe your's are the two prong variety and should cost about $3.00 each.
- polkat
17 Apr 2010 21:18
If your turn signals are working, you can try swapping the cans to see if the hazards work. They are both the same type. If that desn't work you may have wiring problems.
- MFolks
17 Apr 2010 21:27
I'd say open up the left hanblebar switch pod and see if the hazard switch contacts are clean and no broken wires.
- jordash
18 Apr 2010 11:08
Alright, alright, i'll put the bike away
Thanks for the replies, I'll start working on it as soon as there's a rainy day. (psh, hazards...)
I'll post back how it goes.
But now, time for a ride!
'08 KLR650
- jswag5
- whats the big deal about harley, i prefer 4 cyls!!
18 Apr 2010 14:10
i like my hazard lights, when you need to stop on the side of the road it makes you that much more visible.
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
- Bluemeanie
20 Apr 2010 05:57
My '80 KZ650 has four way flashers and a lot of people are amazed that it does! Kawasaki was the leader in tecnology back then.
