84 zn750 horn not working
- morhaven
17 Apr 2010 06:30 #361289
by morhaven
84 zn750 horn not working was created by morhaven
Hi need some assistance with my horn not working.
Test I did:
Tested horn on other kz750 works fine.
Replaced all fuses,
replaced handle bar switch components ( taken from another kz750)
replace entire Fuse Box harness from another kz750
When i turn the ignition switch if I meter the horn wires I get power. but how does the Horn button work does is provide a Ground?
These are the things I notice that could help.
the two front signal light work, but when key is on only the left signal light driving light comes on not the right one.
The headlight only comes on if the bike is started/runs.( not when turning the key)
Now I assume I have the check the entire harness for a short?
Test I did:
Replaced all fuses,
- TeK9iNe
- What did you do!?!
- Thank you received: 28
18 Apr 2010 18:02 #361542
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 84 zn750 horn not working
Sounds like your wiring is going crap.
Shorts/bad connectors or just rott.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- morhaven
19 Apr 2010 07:01 #361642
by morhaven
Replied by morhaven on topic 84 zn750 horn not working
ok so i cut "near the control unit"
the Yellow,black And White black wires if I put them together the horn works...so my issue is with the horn button..
Took it all apart and i see its pretty dirty ...will try and clean those contacts.. seems like a pain..
both my control modules have big dirt..go figure...
thanks again guys..
thanks again guys..
