dyna s ignition setup problem
- terry s
14 Apr 2010 16:32
I just took my dynas ignition out of a old 79 1000 e motor and am putting it in my 80 1000 b motor. I got it hooked up and timed the 1&4 and I had to have the timing plate all the way to one side. I then tried to time 2&3 and it was about 1/4 inch off. I tried adjusting that right contactor and adjusted it all the way it can. I am about 1/8'' away from the timeing mark. I used a timeing light to set these. What can I do to get this set correct? thanks
- loudhvx
Re: dyna s ignition setup problem
14 Apr 2010 16:38
Did the timing light have an advance dial on it? Make sure it's set to zero if it does. Bumping that knob leads to a lot of headaches.
If not, then maybe someone with experience on that Dyna unit will know. Could be the rotor position is different for the two bikes or the timing plate is different.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Old Man Rock
14 Apr 2010 16:52
Several of us had similar situation where the Dyna Plate slots had to be elongated most likely due to differences in the timing advancer units but possibly due to performance engine modifications we made as well.
Follow the link for the installation tut with images I found in my installation and re-perform the Static & Dynamic adjustments....
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- terry s
14 Apr 2010 17:32
good info there. I actually am using a timing light. Is that a no go? I beleive I might have to elongate those slots. I just didn't think I would have to seeing both motors are bone stock.
- Old Man Rock
14 Apr 2010 17:36
Timing light for final but you need to adjust static with the +12Vdc light for TDC initial adjustments if you want to dial them in...
Run through the entire adjustment before opening those slots... You may just find no need on a stock build...
You should have received Dyna installation procedure with your components no... Follow that for everything you need in alignments is there...
Good luck...
OMR
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
14 Apr 2010 18:07
Old Man Rock wrote:
i'd be one of those people.....had to elongate holes for timing adj.......and also had to elongate holes for cover mounting after the adj elongation..DOH.!!....right on the mark now though.....
OMR
- terry s
14 Apr 2010 18:17
I actually am getting 1&4 at tdc but the 2&3 is 1/4'' off with no adjustment left.
- jeffasaki
14 Apr 2010 18:21
Hey OMR thank dyna s file EXCELLENT!
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- z1r1980
04 Dec 2010 03:08
even a vegatable could work that out:laugh:
- andy9802gt
- If it tastes that good, eat it yourself.
04 Dec 2010 03:49
You are setting with the advance mark and not the fire mark correct?
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
