Mounting Accel coils to KZ1000
- gvstenst
13 Apr 2010 17:09
Hi guys
Anybody got a trick diagram or method for mounting accel coils on my 78 KZ1000 project???
Thanks
Thanks
- keith1
Re: Mounting Accel coils to KZ1000
13 Apr 2010 17:23
i mounted mine to the metal rails that came with them and caught the front bolt hole in frame where stock coils mounted and zip tied the back end of the rail to frame....works and you cant see it with tank on....
- 2006hhr
14 Apr 2010 08:12
On my Z1 i used metal hose clamps with bicycle tube insulation and mounted them to the frame, ran the clamps between the plug wire posts. Never had a problem with that solution.
- flht1997
14 Apr 2010 08:32
the mounts that came with my Accel worked fine when i turned them sideways. it is very close to the valve cover with the rear coil but there is a bit of room on mine. was worried about "heat" issues but i really do not think there is a differance between 1/4 inch clearance and an 1/8 inch. plus it has been fine for two years.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
