kz1000 basic wiring
- rob220
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
- MFolks
- Thank you received: 540
The connector has six wires, all needed to run the bike's electrical system:
1.A small BROWN wire(1), the sense circuit, without it the regulator can over charge the battery.
2.The three YELLOW wires(3),mentioned before, one for each phase of the alternator.
3.A BLACK with YELLOW stripe wire(1), part of the ground circuit.
4.A WHITE with RED stripe wire(1), goes to the battery and provides the electrical system for the bike.
If you want to remove the electrical starting system you can, providing the kick start system works.
This would remove the starter motor,solenoid,and related wiring.
Under the engine sprocket cover you will find the routing for the alternator wires(the yellow ones) along with the neutral switch and the oil pressure switch wiring.
- rob220
1075kit
suzuki tl1000 rim
- badnproud
1978 kz1000 with k&n pods couldn't find an airbox for it lol
1980 kz650 e model stock
1984kz440 ltd stock
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- loudhvx
- Thank you received: 1615
If you don't want a starter, just connect the battery + to the fuse 1, fuse 2 junction.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Deofel
MFolks wrote: The charging system has three(3) yellow wires coming from the alternator. They go to an electrical connector that mates with the one from the regulator/rectifier.
I saw somewhere that with the aftermarket 5 wire regulator/rectifiers that the sense wire is not connected. Anyone know about this?
- Thank you received: 1645
