rear brake siezed
- davidfrogg
rear brake siezed
12 Apr 2010 02:33
ok im starting to think im never going to get on the road here i have a 1982 kz 1100 A its running great but now i have a big problem my rear brake pedal is siezed solid ive takin the whole assembly apart and every thing is working but the pivot is seized solid ive done every thing i can think of short of dinomite to get it to move does anyone know where i can buy a new or used one in southern ontario for a fair to decent price? or does anyone have a simalar parts bike in that area for sale?
- PLUMMEN
Re: rear brake siezed
12 Apr 2010 03:43
remove the nut and washer holding it on,spray the pivot down with zep 45 and let it soak.
- harm
- Tom
12 Apr 2010 04:29remove the nut and washer holding it on,spray the pivot down with zep 45 and let it soak
Yes, and if that doesn't get it you may need to put some heat to it.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- bountyhunter
12 Apr 2010 15:24 - 12 Apr 2010 15:25
Kroil penetrating spray is the best I've seen for frozen things. Try something like that.
Last edit: 12 Apr 2010 15:25 by bountyhunter.
12 Apr 2010 16:54
davidfrogg wrote:
Just to confirm it's part 43004 that's frozen?
- davidfrogg
13 Apr 2010 01:50
yes thats the part ive tryed about a dozen diffrent penetrating fluids and ive tryed heat i think its time to admit it i need a new part
13 Apr 2010 05:58 - 13 Apr 2010 05:59
If there's no aluminum in the part, could try soaking it for awhile in muratic acid (cheap and readily available at any swimming pool supply store and probably any home supply).
Muratic acid dissolves rust and may be rinsed away with water.
Would soak part in water/soda solution to neutralize before re-using the part (freshly well-lubed, of course).
Wear goggles and rubber gloves, and be very careful while dealing with the acid.
When finished, dispose of acid by pouring it into a bucket of water (never add water to acid), then add some soda to the solution before dumping.
Last edit: 13 Apr 2010 05:59 by Patton.
