77kz1000
- hmeric7
77kz1000
11 Apr 2010 21:19
yes ive put rear 6 led turns on and a like 20 led tail light. will these to pull alot more juice then a normal taillight bulb and normal single filimants. if it does pull more will my battery still charge enough when riding at night
1977 KZ 1000 LTD
- TeK9iNe
- What did you do!?!
Re: 77kz1000
11 Apr 2010 21:52
LED lighting uses much less power than the OEM lights did.
Your flashers will probly flash too quickly unless they have a built in controller. If they do, all you need to do is go to NAPA and buy the #552 flasher relay. It has a low current draw trigger, and your flashers will work at an acceptable pace.
Peace.
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
