Rectifier / Regulator for 1979 KZ650
  • Gra
  • Gra's Avatar Topic Author
08 Apr 2010 23:53 - 08 Apr 2010 23:57
#359414
In my attempts to sort out the wiring on the bike, the regulator / rectifier which has been replaced seems to be for a 3 phase system (3 yellow wires) not the apparent single phase alternator on the bike.
I have sourced apparently the right rectifier / regulator for the bike, but when I look at the photo of the unit it has 2 yellow wires, 1 red, 1 black and 1 brown. Everything matches the wiring diagram I have except for the brown...
Does anyone know if I can use this part (see below photo) and if so what do I do with the brown wire????
Apparently the other option is you can replace the stator on the alternator with one which is 3 phase. Has anyone done this and is it a simple conversion????
Cheers,
Gra
1979 KZ650 - Under restoration
Last edit: 08 Apr 2010 23:57 by Gra.
  • Gra
Re: Rectifier / Regulator for 1979 KZ650
08 Apr 2010 23:59
#359415
Image attached.... I always have trouble with this???
I hope it works!!!
  • loudhvx
  • loudhvx's Avatar
09 Apr 2010 08:43
#359468
The brown wire is the voltage-sense line. It lets the regulator know what the system voltage (not necessarily battery voltage) is at. Some use the brown wire some don't. (The ones that don't have the brown wire sense the voltage at the battery through the output wire.)
You connect the brown wire to the same circuit that powers the ignition so the brown wire has voltage anytime the bike is running (or even turned on).
You should be able to find a single-phase reg/rec without the brown wire, though.
Are you sure the 3-phase reg/rec is dead? It is possible to use a 3-phase reg/rec on a 1-phase system if the reg/rec is hardy enough.
  • Gra
09 Apr 2010 22:18
#359631
Hey loudhvx,
Thanks for the info.
It seems as though the 3 phase reg/rec is ok but as it has 3 yellow wires, how do I connect the two from the stator to the three yellow from the reg/rec?
Also, if I used the single phase reg/rec will it still work if I don't connect the brown to anything???
  • loudhvx
  • loudhvx's Avatar
10 Apr 2010 14:51
#359714
You can just leave that third yellow unconnected, but tape it up so it won't contact anything.
Absolutely not. If you do that, there will be no regulation and you will burn out bulbs, ignitions etc.
The brown wire must go to a 12v source that gets power whenever the ignition gets power.
  • dcmspikes
  • dcmspikes's Avatar
31 May 2012 22:34
#526207
im starting to think that my reg/rec is going bad. my battery is dead every few days. im going to try testing it this week. does anyone have any ideas of aftermarket (cheaper) reg/rect? for my Honda i just grabbed something from Radioshack that worked great and cost about $5
thanks in advance
Josh
  • MFolks
  • MFolks's Avatar
31 May 2012 23:56
#526230
01 Jun 2012 00:19
#526231
How old is the battery?
  • dcmspikes
01 Jun 2012 11:55 - 01 Jun 2012 12:00
#526279
the battery is a few years old. its a gel type. and it is taking a little longer to charge
Last edit: 01 Jun 2012 12:00 by dcmspikes.
01 Jun 2012 12:12
#526285
I would start by replacing the battery. Ed
  • dcmspikes
02 Jun 2012 01:34
#526388
yeah good call. i have another batt im using tomorrow.
