Blinkers Have Long Delay Before Flashing
- DoubleDub
07 Apr 2010 18:26
Anyone have any thoughts on why my blinkers have a long delay before they start flashing? I have new EMGO flashers from Z1E in the bike (and a second set that I ordered on accident) and they blink fine, just too long of a delay prior to the first flash. I thought it might have something to do with the "beeper" being disconnected, but even with the noisy piece of junk connected the delay still exists.
- KZQ
- Administrator
Re: Blinkers Have Long Delay Before Flashing
07 Apr 2010 18:39
Don't know why they would act differently, first flash to second. But I'd suggest that you check the grounding to make sure the head flex hasn't over worked a wire.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- JMKZHI
07 Apr 2010 19:08
Others have reported that modern bulbs don't work right w the old stock turn signal flasher. One fix is to get a heavy duty trailer flasher from the auto parts store - there should be one that's the same size n stuff. There might be a digital unit that can be used as well.
- DoubleDub
07 Apr 2010 19:14
Thanks guys. I'll check my connections first...my hazards only flash the right side so I need to do some wiring troubleshooting anyhow.
