Wiring Symbols
- Gra
Wiring Symbols
07 Apr 2010 02:50 - 07 Apr 2010 02:54
I have been working through the wiring problems on my 79 KZ650 and have been able to work out what most of the symbols are.
Can anyone tell me what the double circle connections mean on the attached wiring diagram? Is the connection meant to be earthed to the frame??
Cheers everyone.
Cheers everyone.
1979 KZ650 - Under restoration
Last edit: 07 Apr 2010 02:54 by Gra.
- Gra
Re: Wiring Symbols
07 Apr 2010 03:13
I have now attached an image of part of the diagram - apologies for the low resolution...
The connections are two circles connecting a wire.
Help please...
Help please...
- Old Man Rock
Re: Wiring Symbols
07 Apr 2010 05:15
Depicts frame ground....
Your wiring diagram should also have a symbol chart/identifier such as this on mine....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- T_Dub
Re: Wiring Symbols
07 Apr 2010 05:26
If you look closely OMR, one of those is on the positive side of the battery. Note, its on both poles of the battery, both sides of the starter relay, and all 4 signal light grounds. I'd be inclined to say it just indicates a bolted connection with the wire going into terminal rings.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Old Man Rock
Re: Wiring Symbols
07 Apr 2010 05:52 - 07 Apr 2010 05:53
Good point T...
I was actually referring to as in my diagram the designation chart reference being on his wiring diagram...
Could also depict a bolted/screwed termination but don't have his drawing...
Then there's always as we have found in numerous OEM drawings... errors...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 Apr 2010 05:53 by Old Man Rock.
- T_Dub
Re: Wiring Symbols
07 Apr 2010 06:12 - 07 Apr 2010 06:13
Yeah, I'd say as long as the wires are connected to the correct places, you're good to go. I don't think they had any frame grounds mid line, so I just treat all the circles and arrows the same. As long as the wires are connected to their buddies you're good to go.
I didn't realize you were talking about yours lol.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
Last edit: 07 Apr 2010 06:13 by T_Dub.
- MFolks
Re: Wiring Symbols
07 Apr 2010 09:22
The battery in most motorcycles is connected to the frame (usually on an engine mounting bolt)from the BLACK or NEGATIVE(-) terminal.
Kawasaki in it's infinite wisdom may have decided to add additional grounding areas for redundency.
In some electrical circuits this could induce a "Ground Loop" creating a "Hum" in audio devices.
I don't see it causing any problems in motorcycle use.
- loudhvx
Re: Wiring Symbols
07 Apr 2010 09:39 - 07 Apr 2010 10:37
They usually represent a bolt connection, but not necessarily ground.
You can have as many ground points on the engine or frame as you want, as long as they are good connections. It's when they get dirty or become disconnected that wierd problems will show up. It's better to rely on actual ground wires for everything then tie the ground wire to the frame and then to the engine right where the battery negative cable ataches to the engine. The reason you want to have the negative battery cable go to the engine is because the starter uses the engine as ground.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 07 Apr 2010 10:37 by loudhvx.
- N0NB
- Blue handles better
Re: Wiring Symbols
07 Apr 2010 10:28 - 07 Apr 2010 10:29
My experience is that those circles indicate a "bullet" connector where the harness can be unplugged from the device.
Frame ground is indicated by a line with three angled lines coming from the line and the wiring coming from the other side of the line.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
Last edit: 07 Apr 2010 10:29 by N0NB.
- Gra
Re: Wiring Symbols
08 Apr 2010 23:43
Thanks for the posts.
NONB, I think you are correct as there are frame grounds depicted as you say elsewhere in the diagram. I will go with a bullet connector idea and see where it leads me...
- loudhvx
Re: Wiring Symbols
09 Apr 2010 08:02 - 09 Apr 2010 08:07
Gra wrote:
These circled connections are for the heavy battery cables. Obviously they are not bullet connectors. They are bolts. The one by the marker light is probably the ground point (bolt) as the light may be a one-wire light. Notice the other one on the starter motor. Obviously the starter cable is not held with a bullet either. It is a bolt. (T-dub already mentioned all of this, by the way. Even in OMR's photo, the circle is a bolt holding the ground connection.)
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 09 Apr 2010 08:07 by loudhvx.
