electrical part needed
  • bobbisman
  • bobbisman's Avatar Topic Author
06 Apr 2010 15:58
#358809
since there isnt a for sale section i figured this is the best place to start. im working on redoing all the wiring on a 78 kz650. the previous owner did some rewiring which is what i think is causing a slow drain on the charging system. ive been trying to find the right side control switch with the start button and kill switch but can only find the left side on ebay. i was hoping someone may have one for sale on here?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: electrical part needed
06 Apr 2010 16:05
#358811
post ad in classified section top of page B)
06 Apr 2010 16:27
#358817
Here's one on eBay:
Right Control
  • bobbisman
06 Apr 2010 16:44
#358827
thanks 650ed. i just searched ebay and the only one i found was for an 81.
  • bobbisman
06 Apr 2010 16:54
#358831
now my control has a headlight switch on it but i cant tell if this item has one. the headlight switch on mine is just for on and off. if this item does not have the headlight switch would this be a potential problem?
  • Kawickrice
  • Kawickrice's Avatar
06 Apr 2010 17:05
#358838
Is your charging system up to par, stator, regulator, battery?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
06 Apr 2010 17:08 - 06 Apr 2010 17:08
#358840
"now my control has a headlight switch on it but i cant tell if this item has one. the headlight switch on mine is just for on and off. if this item does not have the headlight switch would this be a potential problem?"
You should ask the seller to be sure, but all '77 KZ650's came with the headlight ON/OFF switch. I'd check because some sellers have no clue about what year bike their parts are from. He says it's from a '77 but you can't tell by the dark picture. Ed
Last edit: 06 Apr 2010 17:08 by 650ed.
  • bobbisman
06 Apr 2010 17:09
#358841
one last thing...the only reason im looking for the control is because the previous owner removed the actuall kill switch and rewired a toggle switch instead. i basically just need the kill switch itself and was hoping i could use the one from the ebay item (the top half of the control) and use it as a replacement for the one currently on the bike...thanks again:) i have replaced the stator and regulator/rectifier
  • Kawboy74
  • Kawboy74's Avatar
06 Apr 2010 18:59
#358867
If your bike is a Canadian model from '78 it won't likely have a headlight switch as they came with an always-on feature to meet newer standards. Other units will work but you will have extra wires at the plug end. Good luck!
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • bobbisman
06 Apr 2010 19:19
#358871
its a us model thats why i want the control to have the headlight feature
