Acewell on a 77 kz650
- kruiser13
06 Apr 2010 08:34 - 06 Apr 2010 08:35
Hello all,
I've got a lot on information from you guys in the past, but this is my first original post.
I bought a 77 kz-650 last year, have been trying my hand at fixing it up. I'm getting pretty decent about mechanical issues, I have it running well, but electronic issues I am a severe dunce.
So, my question, I want to replace the tach and speedo with one of the Acewell 2802's, is this hard to do, or even possible on my bike? This would be the first (of hopefully many) modifications I want to make to the bike. Do you need an electrical engineering degree to make the transformation?
Any information would be helpful, I guess I just don't understand how they hook up.
Thanks
Thanks
Last edit: 06 Apr 2010 08:35 by kruiser13.
- T_Dub
Re: Acewell on a 77 kz650
06 Apr 2010 08:41
Watch out in my build thread in the project forum. I have an Acewell 3901 I'm going to be putting on in a couple weeks time. All you need is the unit itself and the proper speedo adapter. They have a magnetic thing you can hook up yourself, but there's also a hall sensor you can screw into your speedo drive thats avaliable.
Theres a few issues with the wiring diagram that they sent me with mine, didn't have the pinouts for the indicator light pigtails. But thankfully I'm an engineering student with full access to a wicked electrcal lab, so I'll get it all sorted out in no time. But yeah, I'll post up a lot of pics and directions, and feel free to shoot me any questions you have about it anytime.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- kruiser13
06 Apr 2010 09:08
Thanks for the response, I'll check out your build when it comes up.
Yeah I just wanted to make sure it would be possible without having to buy seventeen other parts after I bought the 2802.
- T_Dub
06 Apr 2010 09:47
I'm not that certain about the 2802, but all I had to get for mine was the hall sensor, which was included when I bought it from a store on ebay.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Old Man Rock
06 Apr 2010 18:09
The 2802 includes everything you'll need for magnetic pickup. They include 2 sized rotor bolt/magnets...
You will need to fab up a sensor bracket though... Unless of course you order a drive to pickup interface...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
06 Apr 2010 18:10
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
06 Apr 2010 18:11
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kruiser13
07 Apr 2010 08:26
Old Man Rock,
Well, first off sweet bike you got there.
I see you mounted the sensor on the outside of the wheel, but isn't there another magnet that you have to attach to the actual wheel? Where did you attach yours?
Thanks for the info guys.
- Old Man Rock
07 Apr 2010 08:43
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- T_Dub
07 Apr 2010 08:52
Yeah since I'm retaining my Kawi front wheel I got the speed pickup that screws into my speedo drive on the wheel.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- OnkelB
07 Apr 2010 12:44 - 07 Apr 2010 12:46
Old Man Rock wrote:
Except for the sensor, you have to order that separately - $ 10 if I remember correctly.
The sensor is just a simple reed switch that clicks each time the magnet passes it = once per wheel revolution - the position of the magnet relative to wheel center won't matter, you just measure the circumference of the wheel you attach the magnet to, program it it into the Acewell and it'll know the distance travelled per click and convert it to mph/kph.
Trying to use a rotor bolt hole like OMR I had magnet/caliper interference issues when I installed the 2802 on my 1100 so I attached the magnet to my rear sprocket (drilled and tapped the sprocket) and made a sensor bracket that attaches to the lower rear shock mounting bolt. Had to make a longer cable for the sensor, no big deal.
The 2802 includes everything you'll need for magnetic pickup....
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 07 Apr 2010 12:46 by OnkelB.
- Old Man Rock
07 Apr 2010 13:40
"Except for the sensor, you have to order that separately - $ 10 if I remember correctly."...
Naw, mine (sensor) came with it, part of the price...
Oh well....
Oh well....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
